Help Is obi tether constrain broken? - Printable Version
+--- Thread: Help Is obi tether constrain broken? (/thread-1199.html)
Is obi tether constrain broken? - LCKuo - 24-05-2019
Hi I'm trying to make a good look rope,and I have seen the chain sample in demo scene.
Tether constrain works perfectly in the chain sample scene. I can easily clear or generate Tethers.Yellow lines are cleared and generated ,too.
But after I click the " Initialize " button on the same GameObject ,and try to generate Tethers. It seems not working. Yellow lines arnt shown anymore.
Is there something I miss setting?
RE: Is obi tether constrain broken? - josemendez - 24-05-2019
(24-05-2019, 03:15 AM)LCKuo Wrote: Hi I'm trying to make a good look rope,and I have seen the chain sample in demo scene.
Reinitializing a rope resets all per-particle properties. After reinitializing the rope, all particles start out as free particles.
To generate tethers, your rope needs to have at least 1 fixed particle. Tethers work by attaching all free particles to the closest fixed one. See:
http://obi.virtualmethodstudio.com/tutorials/tetherconstraints.html
In that scene, fix the particle near the cube (or create a handle for it, as that's the original scene setup) then click generate tethers.
RE: Is obi tether constrain broken? - LCKuo - 28-05-2019
(24-05-2019, 07:16 AM)josemendez Wrote: Hi,
Thanks that works perfectly to me.  Corazón Corazón Corazón Corazón
