What is the difference between the renderablePositions and position in ObiSolver - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Softbody (https://obi.virtualmethodstudio.com/forum/forum-12.html) +--- Thread: What is the difference between the renderablePositions and position in ObiSolver (/thread-1128.html) |
What is the difference between the renderablePositions and position in ObiSolver - apapaxionga - 27-04-2019 What is the difference between the renderablePositions and position in ObiSolver RE: What is the difference between the renderablePositions and position in ObiSolver - josemendez - 29-04-2019 (27-04-2019, 11:14 PM)apapaxionga Wrote: What is the difference between the renderablePositions and position in ObiSolver Quote from the docs: Quote:If the solver's interpolation mode is set to interpolate, solver.renderablePositions will contain temporally smoothed-out positions that won´t coincide with the actual particle positions at the end of the simulation step. That's why they are called "renderable": they are only used for smooth rendering, but they aren't needed by the solver and thus not calculated unless requested. See: http://obi.virtualmethodstudio.com/tutorials/scriptingparticles.html |
