Using with 2017.4.15f1 possible? - Printable Version
+--- Thread: Using with 2017.4.15f1 possible? (/thread-1046.html)
Using with 2017.4.15f1 possible? - thegreenhell - 05-04-2019
My question is pretty simple.  Is it possible to make this asset work with 2017.4.15f1?  This is the version of Unity currently in use by the program I'd like to use the plugin for.  If possible, I'd be more than happy to make a purchase.  Otherwise, my search to replace the plugin I currently use (Dynamic Bone) will continue.  Thank you for your time.
-GreenHell
RE: Using with 2017.4.15f1 possible? - josemendez - 05-04-2019
(05-04-2019, 01:28 AM)thegreenhell Wrote: My question is pretty simple.  Is it possible to make this asset work with 2017.4.15f1?  This is the version of Unity currently in use by the program I'd like to use the plugin for.  If possible, I'd be more than happy to make a purchase.  Otherwise, my search to replace the plugin I currently use (Dynamic Bone) will continue.  Thank you for your time.
-GreenHell
Nope, 2018.1 or above is a must due to missing Unity features in previous versions.
