Help Performance issues - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Performance issues (/thread-1327.html) |
RE: Performance issues - josemendez - 10-12-2019 (10-12-2019, 05:47 PM)BisuDagger Wrote: IIRC, because of the long length of the rope and load attached to it, the load was springy and didn't have a smooth movement when I used cursor.ChangeLength("using a value between 0 and 1"). This is probably the single worst possible scenario for an iterative, particle-based engine like Obi. Large mass ratios, long cables and iterative solvers just don't mix, as the only way to get decent results is brute-forcing your way trough by using a huge amount of iterations (which kills performance), or a tiny timestep (which also kills performance). The ideal approach would be either a direct solver or a reduced-coordinate based approach (articulations). Both are quite expensive. We have another asset specifically designed for cranes and similar cable-driven machinery, that could work well in your case: https://assetstore.unity.com/packages/tools/physics/filo-the-cable-simulator-133620 Let me know if you want a refund for Obi, as the way you're using it you're not going to get the results you're after. RE: Performance issues - Wattosan - 11-12-2019 (10-12-2019, 04:03 PM)josemendez Wrote: Resolution controls the amount of particles (which is equal to the amount of sections when smoothing == 0). I created a new section asset and instead of using 8 vertices I am now using 3 vertices. It did not improve the performance by a lot though it seems to stay more consistently between 1-2 ms (for LateUpdate). However, now I occasionally get very high performance hits, which is caused by the ObiSolver.FixedUpdate(). The spikes are usually between 8-30 ms. There is sometimes more of them, sometimes less. Any ideas what these could be caused by? |
