RESET Obi Softbody - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Softbody (https://obi.virtualmethodstudio.com/forum/forum-12.html) +--- Thread: RESET Obi Softbody (/thread-3919.html) Pages:
1
2
RE: RESET Obi Softbody - swancollective - 03-07-2023 So just a quick update on my journey of resetting softbodies ![]() Weirdly, the two-line script using the teleport still crashed my editor. I created a completely empty scene only with a solver and a softbody. When I reset its position and exit playmode afterwards, Unity crashes. BUT, your other script does work - I only had to swap the "count" parts to "Length". Here's the adjusted script that lets Unity live (in my case): using UnityEngine; using Obi; [RequireComponent(typeof(ObiSoftbody))] public class ResetActor : MonoBehaviour { ObiSoftbody softbody; Vector4[] originalPositions; Quaternion[] originalOrientations; void Update() { if (Input.GetKeyDown(KeyCode.G)) { ResetToOriginalPosition(); } } void OnEnable() { softbody = GetComponent<ObiSoftbody>(); softbody.OnBlueprintLoaded += Softbody_OnBlueprintLoaded; if (softbody.isLoaded) Softbody_OnBlueprintLoaded(softbody, softbody.softbodyBlueprint); } void OnDisable() { softbody.OnBlueprintLoaded -= Softbody_OnBlueprintLoaded; } private void Softbody_OnBlueprintLoaded(ObiActor actor, ObiActorBlueprint blueprint) { originalPositions = new Vector4[softbody.solverIndices.Length]; originalOrientations = new Quaternion[softbody.solverIndices.Length]; for (int i = 0; i < softbody.solverIndices.Length; ++i) { int solverIndex = softbody.solverIndices[i]; originalPositions[i] = softbody.solver.positions[solverIndex]; originalOrientations[i] = softbody.solver.orientations[solverIndex]; } } public void ResetToOriginalPosition() { for (int i = 0; i < softbody.solverIndices.Length; ++i) { int solverIndex = softbody.solverIndices[i]; softbody.solver.positions[solverIndex] = originalPositions[i]; softbody.solver.orientations[solverIndex] = originalOrientations[i]; softbody.solver.velocities[solverIndex] = softbody.solver.angularVelocities[solverIndex] = Vector4.zero; } } } I know that the teleport shouldn't cause any problems, but Unity is a fickle bitch and maybe it helps any other person who has the same bug as me. Cheers Felix RE: RESET Obi Softbody - spikebor - 09-05-2024 Propagate this code to other users when you see them need to reset any ObiActor (Rope, Cloth,Softbody or whatever) This is needed when teleport, or optimize disable > move solver to new pos > enable back. Code: public class ObiActorResetor { How to use: Setup on Start (softbody is a reference that you wired in inspector, this is for example, it can be anything: rope, obibone, cloth) Code: ObiActorResetor softbodyResetor; When want to Reset / Restore it to starting local position related to the solver Code: softbodyResetor.MarkShouldReset(); |
