Help  How does atmospheric drag work in Obi Fluid?
     I had a quick question regarding the 'atmospheric drag' parameter in the emitter blueprints. Since this is just one editable parameter, what exactly does the variable represent? Is it the drag coefficient? Density? Surface area? Or does it represent the actual drag force – and if so, is it dependent on velocity squared? I would like to create a relatively accurate simulation through the air, and drag is a rather large factor in that.
Thanks in advance!
F17
(28-04-2022, 07:40 PM)Freebird17 Wrote: Hello,
Thanks in advance!
F17
Athmospherig drag is a unitless drag coefficient, opposing the particle's velocity, and only applied to particles near the surface of the fluid. The implementation is done following this article:
http://gamma.cs.unc.edu/SPH_GAS/sph_gas.pdf
You can find the equation for the atmospheric drag force in page 4 (eq 14).
It's implemented in line 356 of the BurstDensityConstraints.cs file.
(29-04-2022, 09:51 AM)josemendez Wrote: Hi there!
Great, thank you so much! Gran sonrisa
